EICTA change HD ready requirements - important info
Discussion in 'LCD & LED LCD TVs' started by tosh hunter, Apr 29, 2005.
  1. tosh hunter
    tosh hunter
    High Definition TV news Posted Friday, April 29th, 2005
    Viewed 725 times.
    Clarification on EICTA's High Def screen requirements
    We've become aware in recent weeks of considerable confusion among the public, manufacturers and, indeed, ourselves (!) concerning the connectivity a screen must have to earn EICTA's new HD Ready badge, signalling guaranteed compatibility with current and imminent UK HD formats.
    It's the component jacks that are responsible for most of the head scratching. Basically, at first reading, the list of requirements originally laid out by EICTA (see our story of January 20) seems to suggest that a screen must have component video jacks as well as an HDCP-enabled HDMI or DVI jack. But it appears that this isn't actually the case. According to Philips and Toshiba, who claim to have clarified the situation with EICTA, a screen only needs to be able to take a YPbPr1 signal through ANY connector; there doesn't have to be a dedicated three-RCA component video connector. For instance, if you can get a 720p or 1080i component signal into a screen via an adaptor and a PC input, that still counts. Or in the case of Philips' PF9986 range of LCD screens, which have no component video or analogue PC inputs, the fact that you can get an analogue component feed in via component-to-VGA and then VGA-to-DVI adaptors means they too can claim to be truly HD Ready. So now you know!
    It's worth pointing out as a parting shot, though, that while this situation might be great for getting manufacturers who haven't put many inputs on their screens out of an HD hole, it doesn't offer any solutions for people who might suddenly find they've now potentially got at least three radically different (to the point of some being analogue and some digital, in Philips' case) bits of AV kit all vying for the same socket...
    heres the link.....http://www.homecinemachoice.com/cgi-bin/shownews.php?id=7877
    :lease:
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Well all this means is that you need the HDCP in one form or another, but the "component" feed can can in thru any sort of connector. That sorts out the 9986 then?
  3. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    As mentioned on another thread, jimg, the 9986 has an HDCP DVI socket anyway, so was already HD Ready. The component input is of no consequence with it.
    Jimmy
  4. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Jimmy, in the original spec you needed HDMI/DVI-HDCP and component. That is why Phillips wanted the re-wording of the spec
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    I see. Seems a bit of a waste of time for Philips to be too bothered about this. The 9986 is coming to its marketing end and the 9830 will have both anyway.
    Jimmy
  6. jimg
    jimg
    Jul 4, 2004
    826
    +58
    I agree, it just confuses people; you still need to be thinking about HDCP!
  7. Jabe
    Jabe
    Apr 30, 2005
    24
    I'm a bit of a noob - anyone know what you would you call this adaptor, where you get it form and for how much?
    I have ordered a Tosh 32LW56 so i need a way of getting my Tosh DVD component output into it.
    Many thanks
  8. jimg
    jimg
    Jul 4, 2004
    826
    +58
    I presume he is talking about a component to VGA converter?
  9. Jabe
    Jabe
    Apr 30, 2005
    24
    Does such a converter preserve the benefits of Component over say, RGB Scart?
    As far as I can work out Component is better than because it has not been compressed to reduce bandwidth for transmission. By putting it through a Component to VGA convertor would I be compressing the signals again, therefore loosing the benefit of Component?
  10. terekhov
    terekhov
    This might help.
    http://www.dvdo.com/faq/faq_cables.html
    regards,
    alexander.
  11. terekhov
    terekhov
  12. Jabe
    Jabe
    Apr 30, 2005
    24
    Than ks Terekhov, this cable looks like it would do the job http://www.dvdo.com/pro/pro_acc_cbl.html
    but the implication is that you would need to by an iScan as well.
    Is this the case, or can I just buy the cable and use it to connect my DVD my TV?
    Thanks for youtr help on this.
  13. terekhov
    terekhov
    Don't know about your Tosh, I've bought Phil 9986
    last week.
    The first one was "old stock" with 1.3 firmware. It
    could do only analog RGB/VGA (digital aside for a
    moment) over DVI-I/DVI-A, no YUV. It went back.
    The replacement unit with 2.3 firmware can do
    YUV (in addition to RGB... apart from 1:1 mess).
    I've not yet tried digital (and HDCP). My Pana
    S97 just arrived, and I have yet to unpack it, but
    reportedly it works just fine even with 1.3 firmware
    on Phil 9986.
    regards,
    alexander.
