EH50-sound from Sky
Discussion in 'Blu-ray & DVD Players & Recorders' started by sunburysteve, Jun 12, 2005.
  1. sunburysteve
    sunburysteve
    I have just brought a Panasonic EH50 but have a problem with the sound from my Sky Digibox. I currently have the system set up a per instructions in the book:
    - The Sky box is connected through Video output to my JVC TV to Ext 2
    - Sky box is also connected to the EH50 from the TV output scart socket to AV2
    - The EH50 is connected to the TV (Ext1) from AV1
    The problem is that Sky isn’t coming through the EH50 in Nicam. On the main 5 channels it says it’s in Nicam but on AV2 it doesn’t say anything (not even mono) and the sound quality is not so good. We have tried changing leads and sockets etc. but it makes no difference. The sky system direct to the TV seems fine. I would be very grateful for any advice anyone could give.
  2. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    Nothings wrong !!
    You only get Nicam from a terrestrial analog signal (i.e regular tv channels). Your Sky box will output stereo into your dvd recorder.... and the sound quality won't be as good as a terrestrial broadcast.
    Brian
