dazm41
Is anybody getting one at £399 it's on the high side but you do get dual HDMI 2.0a/1.4 for audio but it's cheaper than getting a new 4k 2.0a reciver what do think
just pulled the trigger on one of these is there i should know it will be hooked up to a 4k tv for picture and 2nd hdmi to my marantz sr7007 , now there is two of usYes I have one, wonderful bit of kit, anything you need help with?
just like to add a couple of findings with this box now i've had it over a month first of the picture quality is outstanding from blu rays to uhd films don't watch dvds anymore so can't comment did have a couple of issues regarding using the dual hdmi cable solution which i do were the machine failed to lock on to the audio signal it would only recognise dolby digital it was ok with a beta firmware i was using but when updated to the stable firmware v1.2.6.6 it knocked of the sound so i went back to the beta firmware v1.2.6.0 i i contacted the egreat forum and rita on there sent me a pm with a beta firmware v1.2.6.7 with in a couple of days so very good response from egreat there the machine was backed to normal playing all the audio formats there are a couple of niggles but with a new firmware im sure this could be just the best media player there is / that i have .
A 1000 % times better picture quality
It is expensive but I'm happy and the Mrs said there is a big difference in picture quality so win win
i just bought the a5 same chipset firmware etc is it not so what settings you use is it right you can only change settings in 1080p and not 4k , what firmware you on ??A 1000 % times better picture quality
I'm on a beta firmware v1.2.6.7 which won't belong before it's released I suppose, I've a 4k TV I use 2160@30 HDR auto, I use the inbuilt media player not vidon kodii just bought the a5 same chipset firmware etc is it not so what settings you use is it right you can only change settings in 1080p and not 4k , what firmware you on ??
Yes that should work fine - no need to buy anything else.so if I use HDMI OUT from the Amp to one of the HDMI IN on the one connected box and connect the EGreat box straight though to a HDMI IN on the Amp is that correct
