Effective rear dispersion in a small room
Discussion in 'Home Cinema Speakers' started by 3wrLcs, Jan 5, 2005.
  1. 3wrLcs
    3wrLcs
    Jan 12, 2003
    33
    I'm looking for some rear speakers that will provide effective dispersion in a small room (12x11 feet). My fronts are taken care of with JM lab micro utopia Be (2 channel still being my main consideration) and I think that I'll add a JM lab Sib or similar as a center. However, as the room is small I was wondering if something like K4 tripoles may be a better bet that JM lab Sibs at the rear. I've tried small B&W stereo rears (600 S3) before but found that the sound is somewhat localised. I will be sitting about 1 foot from the rear wall so that is a consideration as well.
    Any ideas? My amp is a 2011.
    3wrLcs
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The K4 tripoles are very effective rear speakers but you may want to consider Mission bipole rears as an alternative
