Effect of strand quantity in speaker cable?
Discussion in 'Cables & Switches' started by Grubert, Feb 4, 2005.
  1. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    I've seen several retailers say a good speaker cable should consist of many thin threads, instead of fewer and thicker ones.
    Cable gauge being the same, does one of the following builds have any real-world advantage (apart from physical flexibility)?
    [​IMG] [​IMG]
    Thanks.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    It's really not worth worrying about. Flexibility is about the only difference. :)
  3. summat
    summat
    Dec 16, 2004
    90
    Preston
    Someone might try to baffle-with-bull with potentially lower effective skin resistance on the many/finer cables, but to be honest, as eviljohn2 says, you won't notice any difference.
    Go for the cheapest.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Baffle-with-bull is definitely the case for audio frequencies as skin effect is only relevant at high frequencies. It should therefore be at least considered when designing digital/video cables but is of no relevance when dealing with speaker cables and analogue interconnects. :)
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    An interesting discussion on skin effect http://www.diyaudio.com/forums/showthread/t-21348-p-2.html
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
  7. CfP
    CfP
    If the cables offer the same (or very simlar) total surface area across all strands (which is likely) then most people would be hard pressed to tell any difference.
    As has been stated, if the cables are otherwise the same (purity, construction, etc) then go the lowest cost option.
    CfP
