Effect of EQ and lower power on sound quality
@if ®afiq
After prematurely getting rid of my two15 drivers, I've now decided to get just the one (Rockford P3D4-15). The sealed enclosure size is 130L (after bracing and driver, no filling) - I may add filling.
Before applying any EQ in WinISD, I can pump 1400W into the sub and not worry about xmax being hit. However I loose 8dB by the time I hit 20Hz. (Max SPL 105)
If I smooth this down with an EQ at 20Hz (Q=2, +6dB), I loose just under 3dB (Max SPL the same)but I need to drop the power down to 400W, to keep it under xmax.
What effect would this have on the sound quality? I'd be using the sub for movies only.
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
