EDTV. Will I be able to watch sky 480p?
Discussion in 'General TV Discussions Forum' started by Wilt, Apr 16, 2005.
  1. Wilt
    Wilt
    May 13, 2004
    1,021
    48
    Mitcham, Surrey
    +30
    I have a Toshiba 36ZP48 and was wondering if I buy a Sky HD box without subscribing to the HD channels, will i be able to watch the my current sky+ subcription standard def channels in 480p via component? DVDs look great using a progressive scan DVD player but watching Sky via RGB scart and forced progressive isn't as good.
    Many thanks
    Wil
  2. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    No.
    You can t get sky to have a dvdlike PQ just by changing your connections coz a crappy signal is received by your receiver first of all.
    it s not only a matter of resolution.
    It s qlso a matter of bitrate(compression).
    Sky uses high compression methods just to provide you with a high number of channels.
    The only solution to your problem is to wait till HD arrives which will have not only a higher resolution but it s going to use a difference compression format mpeg4 instead of mpeg2
    so theoritically it will give a stunning difference in pq.
    I m not very good in english but I hope you understand what i m talking about :)
  3. Wilt
    Wilt
    May 13, 2004
    1,021
    48
    Mitcham, Surrey
    +30
    Thanks Lee. I understand you perfectly.
    Wil
