Editing
Discussion in 'Blu-ray & DVD Players & Recorders' started by henryv, Feb 11, 2009.
  1. henryv
    henryv
    Jul 4, 2006
    658
    Greater Manchester
    +88
    I have had my Panasonic DMR-EX75EB for some time and it is great.
    I want to copy a rugby match from HDD to a DVD-R but I would like to remove the first 5 minutes and the last 30 minutes approx'.
    I have read the manual but I cannot understand how to do it.
    Could some kind soul talk me through it?
    Henry.:):):)
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,157
    +7,098
    Hi Henry,
    There are many possible methods.
    Perhaps the simplest. Use the Chapter editing method:
    Play the material at the start point that you want to save, and press the yellow button.
    That will insert a chapter mark.
    Navigate to the end point of the material you wish to keep and press the yellow button again. This will insert another chapter mark.
    Now stop and go to the navigator. Select the title you are dealing with ... and press the sub-menu button.
    Select Chapter view.
    In chapter view select the first chapter and press pause button. This will put a tick on that chapter to indicate it has been selected.
    The second chapter is the one that you want to keep. Bypass that and select the third chapter. Press pause again,
    You should now have a tick on the first and third chapter which indicates they are both selected. The middle chapter [ which you want] should be unticked.
    Now press 'Delete' on the remote.
    You will get warnings that you are about to delete two chapters.
    If you are happy that you have the correct chapters selected, proceed to delete.
    Your title will now be as you wanted.
  3. henryv
    henryv
    Jul 4, 2006
    658
    Greater Manchester
    +88
    Many thanks Gavtech, for your excellent instructions.
    I will experiment with a recording that I am happy to mess up first!:)
    Most appreciated!!
    Henry.:):):)
  4. henryv
    henryv
    Jul 4, 2006
    658
    Greater Manchester
    +88
    It worked a treat Gavtech!!
    So much easier than the manual instructions!!:thumbsup:
    You are a top man!!
    Henry.:):):)
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,157
    +7,098
    :smashin:
