editing VHS-disc
Discussion in 'Blu-ray & DVD Players & Recorders' started by pw29010, Mar 22, 2006.
  1. pw29010
    pw29010
    i want to copy my old vhs tapes to dvd discs, then i want to edit the discs (take out the adverts) could someone tell me how many ways there are to do this/ any help would be appreciated
    thanx
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Once you have recorded a VHS tape to DVD-R or DVD+R you can not edit the disc. The only discs you can edit on are DVD-RAM, DVD-RW and DVD+RW.
    Editing out the adverts on these discs is also time consuming and you will quickly get sick of it if you have many VHS tapes to transfer.
    Is it absolutely essential that you remove the adverts. You can always FF them on the DVD-/+R discs. Personally I leave them in. It's far less trouble than removing them.
  3. Analogue
    Analogue
    Thae only way of practically editing a DVD is on a PC but then (I am learning) the best way is to import the analogue tape direct via one of the commercial capture interfaces rather than using the DVD as an intermediary. Then you can use software such as ULead Video Studio or Pinnacle to easily remove adverts titles etc.
    I have the former but you need to look at their forum for stickys and user comments when recording back to DVD otherwise if you are not careful the end result is of poorer quality than VHS
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,730
    Somewhere in South Yorkshire
    +6,305
    If you use a HDD-DVD machine, you can capture to the Hard Disc, edit there, then burn the end result to DVD.
    Edits aren't exactly seamless, though. You get a momentary pause or some such. Something to do with GOPs (!)
