Editing .ts (DVB) Recordings - Handbrake/Project X advice
Discussion in 'Computer Software & Operating Systems' started by elsmandino, Sep 11, 2012.
  1. elsmandino
    elsmandino
    Jul 18, 2009
    353
    +10
    Hi there,
    I am in the process of tidying up all my .ts files that I have recorded using Mediaportal.
    I would like to edit out the adverts, correct any errors in the stream and convert the files to h.264 MKVs (not just for saving space but so I can play them on my tablet).
    I have been recommended to use Project X for the editing/error correction and Handbrake for the re-encoding.
    Unfortunately, I am having trouble finding any documentation relating to Project X and the user interface is a little unintuitive.
    Any advice would be greatly appreciated.
  2. next010
    next010
    May 29, 2005
    10,761
    163
    +2,105
    Well I cant offer any advice on Project X but what I use and is simple enough for basic editing is SolveigMM (commercial software), it is a lossless output of the video after edits so you can feed it into any x264 encoder, it can also edit x264/mkv files too.
  3. elsmandino
    elsmandino
    Jul 18, 2009
    353
    +10
    Thanks for that - I have never heard of that program and shall give it a whirl tonight.
    Do you know whether it has error correction and frame accurate editing?
