editing software and microsoft SP2?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by 90210, Jun 10, 2005.
  1. 90210
    90210
    Not sure if this is the right place but cant really place where to ask...... I have just splashed out on a new pc and am starting to put all my software on etc. I dont think that my win XP has the service pack 2 on and i know that it has caused some conflict and wanted opinions. I thought if i install it all all it wouldbe best at the outset before any more programmes are loaded? Is there any need to install it at all do you think? I am also going to install pinnacle when i get around to it .
  2. oldjohn
    oldjohn
    Mar 15, 2005
    75
    Rock Ferry
    +9
    I would have thought a new computer would have service pack 2 installed,you can check yourself, go to Start,right click on My Computer and select Properties, it should show which service pack is installed.
    The only problem I had with Service Pack 2 was it caused my modem to crash using AOL,a new driver download solved that problem.
    Hope this helps.
    John.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    I think that the majority of reported problems with firewire & SP2 were with people useing Panasonic camcorders. MS were aware of the problem and I believe made a patch available for download that resolved the problem. Do a search on this forum for the full details as I've never had any problems on my PC with SP2 and therefore can't remember exactly what needs to be done.
    Mark.
  4. davet010
    davet010
    Jul 23, 2004
    384
    +10
    I've got a Panasonic NV-GS 75 and Pinnacle Studio 9, and had no probs with SP2.
