Editing Pictures To The Right Size & Shape
Discussion in 'Photography Forums' started by Garrett, Aug 5, 2004.
  1. Garrett
    Garrett
    Apr 21, 2001
    39,870
    2
    167
    The best thief you’ll never see.
    +6,528
    What do people use to edit there pictures on there computer? I.e. if I want to cut the centre bit out of a picture and then load it to either CD or a memory card how do you ensure it is the exact shape and size to get printed right?
  2. Brian110507
    Brian110507
    There are literally dozens of digital imaging packages which will do what you want ranging from the free download and the ones supplied with many cameras up to ones costing hundreds of pounds, My opinion is that the top two used by many amatuers would be Adobe Photshop ( http://www.adobe.com/products/photoshop/main.html ) and jasc Paint shop pro ( http://www.jasc.com/products/paintshoppro/? )
    I personnally use Serif Photoplus ( http://www.serif.com/photoplus/photoplus9/index.asp ) which although not so well known is a very adequate package.
  3. s2oldskool
    s2oldskool
    Using photoshop (and PSP maybe?) you can apply a fixed aspect ratio mask. Just set the aspect ratio you want, eg 640:480, 6:4 etc and select the size you want, move the mask over the area you want, and crop.
  4. Garrett
    Garrett
    Apr 21, 2001
    39,870
    2
    167
    +6,528
    I use Adobe Photo Shop Elements has that got the masking and if so how do you get it going (what do you click)?
  5. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    The land where The Macallan is distilled
    Open the image you want to crop (mask) and select the Cropping Tool in the Tools palette. It's the 3rd tool down on the right.
    Place the cursor at roughly the top left of where you want the mask to start and drag down until you have a rectangle of roughly the size you want. You can drag and resize this rectangle to the exact size you want using the handles at each corner. When you're happy, double click within the image and it will reduce to the size of the mask.
    Now click Image in the menu bar and select Resize. chosse the size you want ( 800 x 600), click OK. Click File and Save As and that's pretty well it
  6. Garrett
    Garrett
    Apr 21, 2001
    39,870
    2
    167
    +6,528
    Thank but in the last bit if you have not got the ratio right in the first place it just distorts the picture to fit.
  7. Garrett
    Garrett
    Apr 21, 2001
    39,870
    2
    167
    +6,528
    Ah I found out what to do when you choose the framing tool it brings a bar up above your picture in the menu across the screen you can enter the width and hight there and move it round the picture.
    Thank every one for your help. :smashin:
