LittleGreyCat
Having read various threads about editing (I am working up to editing a lot of AVCHD video) one strategy seems to be to convert the original into a lower resolution, edit the lower resolution, then use the results to render the original data to produce the finished product.
Simple editing strategy seems to be dragging small clips from the original data onto a new timeline and optionally inserting transitions between clips.
So the question is - how does the software keep track of where in the original timeline the clips came from so that it can match the low res edited version exactly to the high res original version come rendering time?
Is this all done by recording stuff in a description somewhere in the bowels of the software, is it perhaps in metadata, or is the original timeline data included in the new clip in some other way and then stripped out during rendering?
Just trying to get my head round editing one set of video data and having the results applied to a different (original) set of data.
LGC
LGC
