Editing HS2 recorded DVD's on pc?
Discussion in 'Blu-ray & DVD Players & Recorders' started by TraceyJ, Oct 17, 2004.
  1. TraceyJ
    TraceyJ
    Dec 11, 2003
    83
    I'm really stuck and have spent some time searching the forum for the answer to this but so far no luck.
    I have a home recorded DVD (produced on my HS2) but want to re-record with a nice interactive menu using TMPGEnc DVD author (I've used this before to put digital camera videos on dvd so know it works fine).
    Can I put my DVD in the pc and then just copy the files to create a new DVD with the dvd authoring software? There are 3 file types on there - VOB, IFO and BUP. The software doesn't seem to recognise them though :rolleyes: Do I need to convert them to mpg and if so which files do I need?
    Can you tell I'm a bit lost here?!
    I suspect this is the wrong forum but wondered if anyone else with a dvd recorder has tried this already?
    Thanks in advance.
    Tracey
