editing Hd before burning to disc
Discussion in 'Blu-ray & DVD Players & Recorders' started by passthebiscuits, Dec 30, 2006.
  1. passthebiscuits
    passthebiscuits
    Feb 11, 2006
    47
    Redcar
    Hi could someone please help as I cant seem to get a definative answer from my local electrical stores.
    Is it possible to Edit a programme while it is on a Hdrive before burning it to a disc EG removing adverts.
    If so could you tell me which dvd/HD combo machines will do this...
    Many thanks
  2. Aidoscuz
    Aidoscuz
    Nov 5, 2005
    36
    Dublin
    Yep, you can definitely do that with just about every HD Recorder I can think of. I'd recommend the Panasonic EX75. I've got one and it's absolutely brilliant, picture quality is great and it's really easy to use. Editing programmes on the hard disc is simple as well. You just create chapters at the start and end of ad breaks and then delete them, and then you can burn the edited programme to DVD in a couple of minutes.
  3. JH4
    JH4
    May 6, 2003
    2,463
    83
    +299
    Ditto with Sony - just do an A-B delete and it keeps what's left as one recording, ready to 'dub' ( as Sony call it ) to disc. You can (re)name the recording as well, so it shows the title in the menu when the disc is loaded.
  4. nsherin
    nsherin
    May 14, 2003
    620
    Portsmouth, UK
    +23
    Yep - have done that tonight with my new Sony RDR-HXD560 that I bought earlier today. Very very pleased with the machine.
