Editing DV without a PC
Discussion in 'Blu-ray & DVD Players & Recorders' started by steve 111, Jan 29, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    I am unable to edit DV on my PC due to the software restrictions put on by my workplace :thumbsdow
    Having recently purchased a Panny E60 so that I can archive my DV, what level of editing will I be able to do using DVD-RAM, using the E60 only?
  2. dude1971
    dude1971
    You can fine tune the footage on DVD RAM, that's what I do. You just can't add menus etc :-(
  3. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    Can you define 'fine tune'?
  4. dude1971
    dude1971
    I sure can :)
    I copy an hours worth of camcorder footage via the DV input onto a single sided RAM disk set to record at XP mode. I then use the partial erase to delete the bits that I don't want. I have another Panasonic player hooked up, so I then burn the footage onto DVD-r on XP mode.
    You can't move the chapters around either, but then if you want more features you need a PC :-(
    If you need anymore help, give me a shout mate.
    Regards
    Dude
  5. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    Without a PC....sorry, but forget it.
  6. dude1971
    dude1971
    I know, I know. It's in the dark ages for some of us, but I haven't got the space or the cash for a PC!
