edit software anybody know ??????
Discussion in 'Blu-ray & DVD Players & Recorders' started by bazz7777777, Nov 2, 2005.
  1. bazz7777777
    bazz7777777
    now that a record films onto dvd from sky is there any software out there for pc where i can edit the film to remove the adverts before burning from the RW disk to R disk :hiya:
  2. Mark_a
    Mark_a
    May 27, 2005
    3,318
    +751
    TMPGenc DVD Author will do that - the Pro version down to frame level, the ordinary version down to GOP level.
    Regards
    Mark
  3. bazz7777777
    bazz7777777
    i will have a look for it thanks for your help, one thing though whats gop, sorry for my ignorance
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    GOP = 'Group Of Pictures'. Individual video frames are collected into groups of 15.
    TMPGenc Pro can select individual frame points for editing; the ordinary version can only set edit points at the beginning of a block of 15.
    This works out at about half a second, and maybe the adverts do not always occur at a GOP boundary.
    You might like to investigate Ulead's DVD Movie Factory 4 Disc Creator as well.
  5. alanwalton
    alanwalton
    I use TMPGenc DVD Author and I find it easy to use.Films you need ac3 software for the sound
