Edit Question.
Discussion in 'Blu-ray & DVD Players & Recorders' started by Akcron, Jul 21, 2005.
  1. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    Hi all. Plz help me i have taken some dv footage of last holiday plugged camcorder straight into my sony rdr gx 300 and copied to dvd...what i need is a program that i can edit with on my pc that will take the footage from the dvd..as i do not have the camcorder anymore..pinnacle9 and even the editing software that came with the cam wont do it, does anyone plz know any program that will thx Akky :lease:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    What type of disc did you record onto - DVD-RW or DVD+RW? If you used the former did you record in VR mode or Video? The answer you give will alter what programme is recommended!
  3. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    Its a non RW, dvd - R. and done in VR mode thx for your reply
    Rasczak. very noobie about this , should i have been using RW discs ? :oops:
    thx Akky.
