edit dvd+rw
Discussion in 'Blu-ray & DVD Players & Recorders' started by jackphilips, Oct 13, 2004.
  1. jackphilips
    jackphilips
    Sep 7, 2004
    118
    oxford
    +4
    hi is there any way i can edit dvd+rw on my pc like getting rid off the adverts and so on i got a pc dvd drive but it is not a dvd rewriter do it need to be a rewriter or not
  2. ijd
    ijd
    May 20, 2005
    2,166
    63
    +126
    yes you can do it, it means copying the disc to your hard drive, edit using software like windows movie maker and then copy back on to a dvd, it is a bit long winded, but can be done and yes you would of course need a rewriter, much easier would be to purchase an HDD DVD recorder with edit function but i guess you have only just bought your dvd recorder, not to sure if you could hook your dvd recorder up to your pc very easily, depends on your pc connections/graphics card. however there are many interfaces that would allow you to do this.
  3. jackphilips
    jackphilips
    Sep 7, 2004
    118
    oxford
    +4
    You know your stuff i will give you that.
    God that was a while ago i had xp then:clap:
  4. ijd
    ijd
    May 20, 2005
    2,166
    63
    +126
    its my job and my hobby:D
