Edifier S350DB - High pitch noise at 48khz
Jaythemasterbuilder
So i got these speakers today, massive upgrade compared to the G560's! It's literally night and day, i can't believe what i've been missing out on all these years buying gamer speakers. Though this is still a entry level, its truly astonishing!
Anyway, i noticed straight off the bat that no matter what interface i used, optical, cox, bt etc there was a high pitch noise coming from the speakers. However i had a play with the sound settings and i changed it from 16bit 48khz to 16bit 44.1khz and the noise went away!
Just to add, i also tried a different mains socket, different extensions and different optical cables as well with the same result at 48khz it has a high pitch noise coming from both speakers. I've yet to try a different RCA to 3.5mm cable which should be coming tomorrow.
Is this something that the speakers can't handle or are they faulty?
Thanks in advance!
larkone
Faulty
Jaythemasterbuilder
Faulty
Thanks mate, i've ordered another set to compare and see if i can resolve this.
If anyone else has any other ideas, please do post in here.
Thank you
