Eclipse DVD-595 : Firmware Death
Discussion in 'Blu-ray & DVD Players & Recorders' started by DavidMalone, Apr 25, 2002.
  1. DavidMalone
    DavidMalone
    I have just burned a dvd-rw of a home movie, i then put this into my Eclipse DVD-595 player which couldn't read the disc.
    The player then brought up an obscure menu to the effect HD/FW upgrade, thinking i was trying to upgrade the firmware :(
    Two seconds later my machine turned off and is now completely dead.
    Does anyone know how i can reset the firmware on this machine,
    taking into account i will probably have to open it?
    Yours Disparingly.
    Dav
  2. DavidMalone
    DavidMalone
    Still looking....
  3. encaser
    encaser
    Mar 15, 2001
    2,390
    116
    Suffolk/Essex
    +540
    Don't open it you'll void any warranty, assuming you have one. In which case why not contact reseller?
    Homepage in owners documents for possible contact/firmware?
    Tried putting dvd in and restarting to see if spin up cancels state?
    No physical reset switches onboard any where?
    Richer Sounds do Eclipse, may be they'll have advice?
