I tried to do what you suggested pedro butalthough I got the channels I wanted , they don't seem to be in digital just analogue. The only digital channels I managed to get were a couple of Parisian test channels and some Spanish channels I think(Berbere channel,etc).
How do you switch it from analogue to digital to scan?
Thanks again in advance
I'd have to do it from memory ...
Berbere TV channel is digital so you have already started to scan in the available digital ... [it's subscription so you won't see a picture but you did it OK]
I would expect a lot of the frequencies etc.. need updating.
You have to go through the menus to find EDIT or ADD TRANSPONDER and edit or add the new transponders..
Start with adding or editing an existing transponder to this for France 2 etc.....
Frequency ... 11591
Pol'..............V
Symbol Rate..20000
& then click on SCAN... you should get France 2 etc..
If it doesn't have a space for Symbol Rate you are in analogue mode - so move on to the digital settings
have a look at
lyngsat 5w for all the digital settings for all the latest channels & look at the above one to see how they are all listed so you can add the others - you just want the free ones - in pale yellow.
