Answered Echo Plus compatible heating controls? (without a bridge/hub)
Discussion in 'Smart Home, Climate Control & Security Forum' started by BikeNutt, Oct 11, 2018.
  1. BikeNutt
    BikeNutt
    Sep 5, 2006
    1,205
    48
    London
    +78
    Hiya,
    I'm in the process of replacing my hot-water-only system for a combi boiler and it would be nice to be able to control the thermostat from outside the house, BUT...
    I'd prefer not to have a bridge/hub connected to my router when my Echo Plus could do the job? (I find the idea of 'black boxes' connected to my router quite ridiculous, frankly.)
    I use HUE and Sonoff devices throughout the house and the Echo Plus/Alexa App work just fine using the appropriate skill.
    Are there products out there that can do this?
    Thanks in advance for any advice.
  2. Best Answer:
    Post #3 by neilball, Oct 21, 2018 (1 points)
  3. pyrotenax
    pyrotenax
    Apr 3, 2006
    939
    2
    4
    46
    Omnipresent
    +146
    Hive ? Nest ? Tado ?
  4. neilball
    neilball
    Jan 7, 2005
    2,890
    Scottish Borders
    +629
    Best Answer
    Honeywell Evo Home can be added to the list too (has built-in wifi to connect to your network so no additional hub/gateway box needed)
