ElectricDreamZZZ
Was wondering if the Amazon Echo link (non amp one) can act as a suitable decent pre amp for a 'dumb' power amp. Will it satisfactorily control volume, and tone controls? ( believe you can change eq in the smartphone app).
I just want a pre amp / basic streamer and it is compatible with my echo dot etc for voice commands. I was given the power amp by my brother and need some sort of pre amp as echo dot via rca into the power amp doesn't seem to work very well, volume doesnt go high enough etc...
