Ebay blackout blinds.. Any1 had any experience?
Discussion in 'Projectors, Screens & Video Processors' started by smashed, Jun 28, 2005.
  1. smashed
    smashed
    Feb 7, 2005
    2,779
    +162
    Im just about to purchase the Benq 5120, and want to find a cheap, but not rubbish, way of projecting, and have figured that blackout blind is the way to go.
    My room is 9ft wide, and I have a 36ZP48, so I think Im going to have to put that to 1 side of the room, leaving me just over 6ft to play with.
    The downside is that widescreen mode for DVDs etc will mean its only around 3ft deep :( (Another problem I dont know how to get around)
    I have looked on ebay, and you can get blackout curtains of around 200cm for about £25, but would like some help deciding.
    It states that its a pair, so do i assume that its only 100cm x 2, and therefore wont do the job??
    Should I be buying a roller type blackout blind? Or are ebay 1's cheap quality and not worth the hassle?
    Or should I go looking round B&Q etc to find a solution?
    I dont really wanna pay more than £70 i guess, and the less the better if I can maintain some quality.
    Any help greatly appreciated :)
    Rob
  2. dyl33
    dyl33
    Feb 14, 2005
    24
    ikea do a great black out blind for only £20 and thats for a 2m blind
    Have seen on ebay same blind being flogged for well over that price and being sold as
    a screen and not a blind so be careful on e bay
    link for blind
  3. smashed
    smashed
    Feb 7, 2005
    2,779
    +162
    Cheers. I tried to find blackout blinds on the Ikea website, but couldnt find them.
    I have since bought some blackout lining from John Lewis, but could maybe get the blind, and then use the lining for my curtains to help darken the room.
    Thanks for your help :)
