easy to wire scart cables?
Discussion in 'Cables & Switches' started by sirp, Jul 31, 2003.
  1. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    is it easy to wire a scart cable? reason i ask is, i want to get one down my LMP mount, cable will go, but not the connector, so one end would have to be wired in after dropping it down the shaft!
    anyone in notts fancy earning a few quid wiring it for me after ;O)
    cheers
    P
  2. andypaton
    andypaton
    Sep 15, 2002
    13
    bedfordshire
    It’s just the bulky housing that needs to be removed not the wires or connectors, so it’s easy.
  3. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    oh ok Andy
    do you know which decent scart cables i can get which allow me to just remove the housing..i looked at one i had at home, and i couldnt see how i could get the housing alone of that one?
  4. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Depends on the type of connector. If present, unscrew the cable strain relief (round nut). Prise the plastic body apart with a flat screw driver. Remove the metal shroud. From the pin side, grip each pin and push though the body of the plug using long nosed pliers. Depending on the cable you will then have up to 21 wires hanging free. Note the pin locations before starting. Good luck.
