Easy to use, with excellent image quality??
Discussion in 'Photography Forums' started by chez, Dec 20, 2004.
  1. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    I use a panasonic DMC-FX7 for day-to-day use because I find it fits nicely into my pocket and still has reasonable image quality.
    I am going to Hong Kong in March and the first thing I want to do out there is buy a more advanced (and probably larger) camera o use both out there and at home (for times when image quality is more important than size).
    I want to spend a maximum of £500 and I understand that cameras are significantly cheaper over there.
    Can anyone give me any idea of how much cheaper cameras are there than here?
    Does anyone have any recommendations as to models which cost around are likely to cost up to £500 there??
    So far, the Nikon Coolpix 8800 has caught my eye due to it's apparant ease of use and it's image stabilisation.
    Thanks in advance
    Chez
  2. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Buyer beware.........http://www.bubbachan.com/photoshopHK/shophk.htm
  3. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    Thanks for that, I had already looked into it and am well aware of the scams that happen and that Nikon don't offer an International Warranty....
    Would still appreciate any recommendations though...
