Easy to use camcorder?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by stevedster, May 2, 2007.
  1. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    A girl in work has asked my advice for a good camcorder that is easy to use perhaps uses mini dvd's or something that can be popped straight into a player once done? i said ahdd one would be better, budget is 'acouple of hundred'.
    any ideas or advice would be great, sorry i dont have more to go on :rolleyes:
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Well for £200 you won’t get a HDD cam, unless you find a great deal or maybe in import or ebay. Closest would be a entry level JVC MG21, which I’ve seen for £230. You can’t get a decent DVD cam either for £200.
    In terms of quality, HDD cams and DVD cams use the same MPEG2 technology… so there is no advantage there for HDD cams. HDD cams do have some advantages in terms of use, e.g. with DVD you are limited as to how much fits on a disc (20 minutes in best quality mode). But if she wants to shoot and pop into a DVD player, then DVD is the only format which does that. And they are a bit cheaper than HDD, so you can get more for your £200.
    Panasonic Panasonic VDR-D100 is a decent entry level DVD cam, available for £228 here http://www.cameras2u.com/products/d...er=prr&tduid=07aa6d532abed4ee9d257d1df9993571
    In this price range she’ll get better quality for the money with a DV (tape) model such as the Canon MD101… but with this she would have to either capture to a PC, or use a DVD recorder, to create DVDs.
