Easy question - replacing a centre speaker
Goof
Established Member
Got my first seperates system about 6 weeks ago, Tannoy FX5.1 with a Yam 5630 receiver and will soon be adding a KEF PSW2000 sub to this.
However, the small centre satellite looks a little daft in the middle of the floor where it is placed (and juts in front of) my screen which is just a couple of inches from floor level.
I want to replace the centre with a 'proper' full sized channel - bearing in my the Tannoy's satellite is 6ohm and 100wpc, what spec/model should I be looking at for replacement? (ie. does the replacement have to be 6ohm or is 4/8 acceptable?). I'm guessing I want the 100wpc power at least (or closely) matched?
Ian J
More important than the impedance and power input of a proposed centre speaker is what it sounds like as it should be a tonal match for the front pair.
Goof
Established Member
Thanks Ian, so it's really just a 'suck it and see' type thing?
Tbh I'm no audio file (yet!) so is there anything suitable you know of on the market, the cheaper the better!
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
