Easy DVD catologue
Discussion in 'Movie Forum' started by Dak, Oct 13, 2003.
  1. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Does anyone know of a simple way to create a catologue of the DVD's that I own?
    I just want a simple list of what I have, and which version / region and want to try and do it without having to write it all out / type it up.
    Main reason I want it is so that I can export it to my PDA and try and not keep buying the same DVD's more than once (yes, I am that stupid).
    Apologies if this has been covered before, a search revealed nothing, but I couldn't think of many keywords to use.
    Ta
    Dak
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
  3. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    I use my own custom database created in MS Access 2000.
  4. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    but you still need to enter every title by name and enter the region as well, right?
    I like dvdprofiler: enter UPC and voila and from time to time contribute a profile to keep the thing running.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    Yes but I found that a lot of my titles weren't in and I couldn't be bothered entering the UPC code and details etc.
    Also didn't like the irrelevant 'record number field' that makes no sense especially if you delete a title then you are left with 'gaps' in this field.
    Why can't they just calculate the record total from the number of records like we db developers do. Never heard of a db that stores 'record numbers' before (maybe I'm just being picky) :lesson:
