Easy - Denon 3805 TV hook up Question...
Discussion in 'AV Receivers & Amplifiers' started by devs, Mar 17, 2005.
Tags:
  1. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    How can I get the sound from my TV out to my speakers via a 3805? So far I've tried connecting to the 'Audio In (TV)' on the 3805 yet it didn't work when selecting the 'TV Ext. In' mode... Am I missing something?
    Thanks,
    dEVS! ;)
  2. adrianl
    adrianl
    May not help but I have 2805. Like you I route the L & R audio from TV to TV In. I then just select 'TV' as an input either on Function dial or via remote. I'm not sure what the 'TV Ext. In' setting is but maybe that's the problem (on the 2805 Ext. In is just for inputting decoded multichannel signals from another device).
  3. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    Hi there adrianl and thanks for the reply mate!
    On the function Dial when I select the TV option the display changes to 'TV Ext. In'. I've just noticed that I can change the modes of this to 'Analog' 'Analog Only' and 'Ext. In'. Yet it didn't work on any of these selling either?
    Any thoughts?
    Thanks!
  4. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    adrianl scrap that question mate - its working! It was a damaged cable - just tried with another and its working fine now!
    Thanks for the help,
    Devs. ;)
  5. adrianl
    adrianl
    Glad it's all working now - always the simple solutions you overlook isn't it?
    Just checked 2805 again and it just says 'TV', so it prefers more concise descriptions to 2805!
    I like using it for TV, except it really shows up what I previously thought was good sound (for a tv) on Viera when you switch back to sound directly from TV! For a few seconds it sounds awful by comparison then you get used to it...
  6. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    Funny - I know what you mean, it puts your TV to shame very quickly! ;)
    Thanks for the help and have a good weekend!
    Devs.
