Easy bulb replacement?
Discussion in 'Projectors, Screens & Video Processors' started by Les E, Aug 30, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    I am thinking of buying a PJ in the Infocus Screenplay range, but I am wondering how easy is to change a bulb on one of these PJ's and is it something I can do if I ordered on mail order or is it more something a supplier/installer needs to do?
    May be a stupid question, but I have heard one supplier suggest it would need to come back to them for replacement...I am counting this was a gimmick to get more money out of me!! :thumbsdow
  2. Dirk_Diggler
    Dirk_Diggler
    I've got the Themescene H30A and it shows you how to change it in the manual. Looks as if it'd take about 5 minutes and looks easy enough.
  3. IronGiant
    IronGiant
    Jun 7, 2003
    61,567
    Oxford UK
    +38,359
    Should be easy enough if you have a sympathetic bank manager, given the arm and a leg new bulbs cost ;). Most are a case of undoing a screw to open a cover, flipping a lever, dropping in the replacement and reversing the procedure.
