Easter Eggs and access thereof
Discussion in 'Movie Forum' started by IanB, Dec 13, 2001.
  1. IanB
    IanB
    Nov 1, 2001
    101
    16
    Shropshire UK
    I read somewhere of an extra feature hidden in the menus of Gladiator. Apparently you click on Richard Harris's breast plate and you access a trailer. I can find the said scene but I can't select the breast plate.
    I'm playing this on my home DVD player (Technics A10) should I be using a PC?
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,606
    7
    167
    Birmingham, UK
    +10,475
    No it will work on your player.
    What do you mean by 'correct scene'?
    It's not in the movie, it's in the menus and therefore not in any scene.
  3. IanB
    IanB
    Nov 1, 2001
    101
    16
    Shropshire UK
    I meant I can find the 'place, menu option, still, what ever I should have called it' :blush: but can't highlight the breast plate.
    Does it 'light up' the same as the other options do?
  4. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,606
    7
    167
    Birmingham, UK
    +10,475
    Yes it does. I usually highlight the obvious options and then press up,down, left and right from each. You should find it.
  5. kenjolly
    kenjolly
    Mar 11, 2001
    101
    Blackpool
    +5
    I was wondering which region disc you are using - On the R2 verison I don't think there is this particular easter egg. Not sure about this but some easter eggs are 'owed' by someone other than the distributor of the film - hence R2 discs don't get that easter egg.
    The main extra on this disc is the Rhino scene and storyboard. You have to go into the deleted scenes, start the last one and press skip on the chapter search (or something like that - it's been a while !). Anyway part of the fun is trying to find these things !
