Easiest and Cheapest way too get DTS ?
Discussion in 'AV Receivers & Amplifiers' started by HighlandeR, Sep 23, 2001.
  1. HighlandeR
    HighlandeR
    Hi, I have the Sherwood R-925RDS amp, its the one from Richer sounds back in 1998 (very popular) has Dolby digital 5.1 and 100x5.
    But it doesnt have DTS, I also have a SCAN DVD player...
    Whats the cheapest and best way too get DTS without upgrading the entire Amp/reciever or DVD player?
    Any ideas..
  2. Jase
    Jase
    Mar 16, 2001
    10,813
    United Kingdom
    +2,693
    You could always buy a processor such as the Yamaha DSP-E800 it used to be about 300 quid, probably cheaper now.
    This will give you DTS. It also has 3 channels of amplification. So you could use these across the front 3 channels & your sherwood for the rears.
    The Yamaha has got a very good DTS/Dolby digital processor as well as good DAC´s so you should notice an improvement over the Sherwood.
    Trouble is if you have to spend 300 quid you could probably pick up a new Amp or receiver such as Denon 2801 or Yamaha 620.
    I would personally get a new amp and sell off the Sherwood.
    Hope this helps
    cheers
    [ 23-09-2001: Message edited by: Capt. Pugwash ]</p>
  3. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Quote from Capt Pugwash <br />'It also has 3 channels of amplification. So you could use these across the front 3 channels & your sherwood for the rears'.<br />Would this work? The DSP 800e is designed to partner a stereo amp with line outs only to the main fronts and power outs to a centre and rears.<br />So if you powered the front 3 speakers with the Yam you would get the rear signal coming from the front speakers I think. Perhaps I have misunderstood this.<br />Anyway would definitely reccommend the 800e.<br />Richard
  4. Desmo
    Desmo
    Jan 4, 2001
    14,450
    Braintree, Essex.
    +6,491
    Personally I wouldn't bother. It's not worth upgrading just to get DTS.<br />If you're looking for a general upgrade anyway then fair enough but spending money just so you can hear DTS is, in my opinion, just not worth it.
  5. Jase
    Jase
    Mar 16, 2001
    10,813
    United Kingdom
    +2,693
    Oops! Yep. Sorry!
    Richard´s right.
    My mistake <img src="redface.gif" border="0">
  6. HighlandeR
    HighlandeR
    ta for quick replies, I tend too agree I guess<br />it would be far more easier too sell and just buy an amp/reciever again <img src="smile.gif" border="0">
    I mean I can pick up one for about £150-200 anyhow.
  7. HighlandeR
    HighlandeR
  8. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i agree . don't worry too much about it . it's not worth the bother just for standard dts
    on the low end stuff there is'nt going to be a great diference .
    you would be better doing like me . i am saving till i have the money to get somthing like the denon 3802 . then you get prologic 2 dts es ect ect.
    it's just not worth going out of your way for the adition of dts . just my opinion though a lot of people seem to think otherwise
