Earphones reviews for the poor
Discussion in 'Headphones, Earphones & Portable Music' started by gerbilly, Aug 12, 2005.
  1. gerbilly
    gerbilly
    Mar 20, 2005
    2,186
    Hamilton
    +94
    Some of cant afford to pay above £40 for earphones without having to come up with a good excuse to the wife. :D
    here Goes
    Sennheiser PX100 - 4 OUT OF 5 - Good quality sound from these earphones. Bass and Treble are fine but they do tend to leak a bit of noise which will irritate whoever is sitting next to you. As a result of this you tend to listen to your player at louder levels which makes it even worse for the mug next to you.
    I-Pod Earphones - 2 OUT OF 5 - At first it sounds ok, but then they start to hurt after an hour and you do notice that the sound seems stifled with anorexic bass and treble.
    Sony Futopia E71 - 3.5 OUT OF 5 - Fit very comfortably in the ear. Bass is excellent but not as amazing as I was led to believe. Treble though was lacking and again I had to put it up louder than I would like.
    Sennheiser MX500 - 4.5 OUT OF 5 - These ones dont fit into the ear canal but they do sound louder than the Sony phones but the bass is a tad less heavier. Very comfortable fit and probably my fav out of the 4.
    I would love these Shure earphones but I wont pay the same amount for earphones that some people pay for their MP3 players.
    Any reviews of other earphones around this price level.
  2. Danfan
    Danfan
    Have you considered Koss Porta Pro?
  3. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    Thats the Sony EX71. These being canal 'phones, the idea is you put both channels in so outside noise is isolated/quietened. I have found them to be quieter than others, but the noise isolation out and about makes up for it. I never said the bass was overpowering, just a little exaggerated
    There are also EX81's, that add ear hooks for better fit. These have better clear sound, like:
    Panasonic RP-HJE50, another pair of canal 'phones, but more balanced clear sound than the Sony's. I'd say these and EX81 are about equal
    There are closed ver of the PX100, called PX200. £10 more, but less sound leakage. I've not tried, but apparently sound slightly more muffled
    Buy the Sony's off amazon.co.uk for cheapest + free delivery
    Pan's off ebay. Don't buy from Dixons, Comet or Currys for rip-off £30/35
  4. shadowritten
    shadowritten
    Hate to bang on like a stuck MP3, but I still vote for the Sony MDR-J20s. Very comfortable 'H' type in/over ear hook fit, plenty of warmth, depth and punch in the bass, a reasonable midrange presentation and no shrillness or shreiking at the high end - just crisp, bright treble. The over ear hooks are flexible rubber, so if you accidentally sit on the cord, the phones just drop off/out of your ears - meaning a lessened risk of yanking the connector wires out of your cans! And all for just £15!
