e85h-HDD
Discussion in 'Blu-ray & DVD Players & Recorders' started by maxwan, Nov 22, 2004.
  1. maxwan
    maxwan
    Mar 19, 2003
    591
    southyorks
    +12
    I have changed the original 80 gig HDD for a 160 gig HDD but never thought would the machine know it has more space to record ?
    can you help or have i wasted my time
    kind regards
  2. HMHB
    HMHB
    Nov 11, 2001
    25,514
    Nottinghamshire
    +3,851
    I think you've wasted your time, these machines only work with the original HDD size as far as I know.
  3. Bosco
    Bosco
    I'm sure that it would need a firmware upgrade to recognise this and you're not going to get that legit from Panasonic. Have you tested it yet? Why not just set it to record durning the day/night at XP and see how much you get on it.
  4. maxwan
    maxwan
    Mar 19, 2003
    591
    southyorks
    +12
    thanks lads, I will try recording and see how much it will hold -- other than that it will have to go in my pc
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    You have no hope of it using the extra space, and as the firmware has never leaked you won't be able to upgrade it either.
    Indeed if the new drive uses significantly more power than the old one you are likely to run into problems when burning dvd's. Unless the old one is faulty or too noisy you would be better off putting it back in and using the new drive in your computer where it can all be utilised.
  6. maxwan
    maxwan
    Mar 19, 2003
    591
    southyorks
    +12
    I have tried leaving it recording and it recorded for 18 hours in XP mode so now I know thanks bosco.
    as for burning dvd's I have never had any problems but if it cannot use all the disk space then back in goes the original
    thanks lads
  7. Bosco
    Bosco
    All you can do is hope that some hacker manages to get into the firmware and releases a hacked version (which is always risky to use anyway). Also, good point made by kenfowler3966, if the HDD does use significantly more power you could end up causing damage to the power supply within the machine (this is why most new PC's have 300+watt power supplies, it mainly to deal with the extra drain from higher processor speeds and larger HDD capacities.
