E85/Viera help please
Discussion in 'Blu-ray & DVD Players & Recorders' started by lazzer, Jul 9, 2004.
  1. lazzer
    lazzer
    Apologies if this has been asked before, but could anyone please enlighten me as to how to record from the Virea's built in DVB tuner onto the E85?
    Any help much appreciated!
    Cheers. Lazzer :)
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
    One of the Scart sockets on the back of the TV should be capable of outputting a signal from the TV. You can connect that to the AV2 on the E85 which will then record what your TV is seeing.
    IMHO you be alot better off getting a dedicated Freeview box as this will enable you to record in high quality RGB - you TV will probably only output composite.
    Consult the guys on the Freeview forum for the best decoders:
    http://www.avforums.com/frame.html?http://www.avforums.com/forums/forumdisplay.php?f=48
    ...although some good options are:
    Panasonic TU-CT30
    http://www.rgbdirect.co.uk/ProductDetails.asp?ProductCode=2109
    Sony VTXD800
    http://www.rgbdirect.co.uk/ProductDetails.asp?ProductCode=1996
  3. lazzer
    lazzer
    Thanks Rasczak,
    Will investigate the AV2 suggestion but am currently using a component lead to connect the E85 to the Viera. Will this be affected at all?
  4. apreading
    apreading
    Jun 28, 2004
    283
    +15
    Is there a Q-Link thingy? Isnt this meant to allow the E85 to record from Panny Tvs with Q-Link? Dont know how it works, but worth looking at as I was under the impression that this was its intended purpose.
  5. apreading
    apreading
    Jun 28, 2004
    283
    +15
    BTW I got the Panny TUCT30 (dont confuse with the 20 which only has one scart socket) for £59 inc VAT from digital-point.co.uk
    And I know Amazon are doing the Sony for about £80 now...
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
    No - youll be able to keep that connection (as it allows you to watch DVDs in the best quality). However you'll need a Scart running from the TV to AV2 on your DVD recorder.
    As Apreading points out there are lots of cheaper places than the RGB Direct links I quoted - they were for information only and I should have specified that more clearly.
  7. apreading
    apreading
    Jun 28, 2004
    283
    +15
    No probs - the ones I quote may not be the cheapest either, just what I came across in the last week or so...
    I do think a separate digibox is the best way to go though - cos presumably you would otherwise have to watch what you are recording?
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
    Yes - not ideal.
  9. lazzer
    lazzer
    Thanks fellas for your input........ :)
    Lazzer
  10. nwgarratt
    nwgarratt
    May 5, 2002
    26,328
    +2,838
    The TUCT30 also has a timer which works with the external link function of the recorders. This is very useful for some people.
    A lot of timers on other Freeview boxes won't work with the external link.
