E85 Lip synch problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by HMHB, Dec 28, 2004.
  1. HMHB
    HMHB
    Nov 11, 2001
    25,445
    Nottinghamshire
    +3,750
    I've transfered all 6 episodes of Max & Paddy from Sky+ onto the hard disk of my E85. I recorded this in XP mode and all is fine with that. I then edited it all down (by deleting chapters) and it was 2 hrs 19 mins total, so I thought I'd see what it would be like in FR mode dubbed to DVD-R. The picture quality seems OK but there is a noticable lip synch problem which is not present in the hard disk version of this. Does this always happen ?
  2. Nelviticus
    Nelviticus
    Jun 21, 2003
    468
    Hitchin
    +68
    No, it shouldn't do. I'd try recording it again. Have you successfully recorded to the same type of DVD-R before?
  3. HMHB
    HMHB
    Nov 11, 2001
    25,445
    Nottinghamshire
    +3,750
    Yes, I've used these DVD-Rs a lot (Verbatim) with no problems. I successfully dubbed another program from the same batch of stuff I'd brought across from Sky+ but I used high speed dubbing mode as it was less than an hour and so didn'r need to be re-encoded.
    I think I bring them across from the Sky+ box again in 2 groups of 3 episodes and do them in SP mode so that I can then high speed dub them.
    It seems a shame though if re-encoding always causes lip-synch problems.
  4. Nelviticus
    Nelviticus
    Jun 21, 2003
    468
    Hitchin
    +68
    It doesn't cause lip-synch problems normally, if it keeps doing it there's a problem with your machine. You could have just been unlucky!
  5. okcomputer331
    okcomputer331
    any update on this issue john? I'm thinking of buying the panny
  6. HMHB
    HMHB
    Nov 11, 2001
    25,445
    Nottinghamshire
    +3,750
    not had the chance to try it yet but will do so tomorrow.
