E85 keeps rebooting with DVD-R/DVD-Ram disc's
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bal2005, Sep 18, 2005.
  1. Bal2005
    Bal2005
    Apr 25, 2005
    170
    UK
    +3
    I have needed to start a new post as my post
    http://www.avforums.com/forums/showthread.php?t=244830
    Doesn't now relate to the issue.
    For some reason my E85 is now rebooting on the first time I insert a disc's or try to format a DVD-RAM.
    Also this happen's when I am recording on high-speed dubbing which is why I had the other post.
    Have I got a faulty machine or just need to try and do a firmware update?
  2. Bal2005
    Bal2005
    Apr 25, 2005
    170
    UK
    +3
    Ok, I've think I've sorted it.
    I opened my recorder up and made sure everything was ok, which it seemed to be.
    I then connected the recorder back up and now everything works.
    Maybe I just needed a 5 minute powerdown which must have reset memory like PC's have things left in memory until you do a hard power off.
    I have burnt a DVD-R and also to a DVD-Ram.
  3. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +297
    I switch all my dvd recorders off at the mains when not using them. Panasonics OK because they hold all the info. JVC a pain because I have to reset year, date and time each time its switched off at mains.
  4. Bal2005
    Bal2005
    Apr 25, 2005
    170
    UK
    +3
    Just had the same problem again.
    Gonna try and copy what I can of the HDD to DVD-Ram.
    But you are right that my latest Ritek disc's make a loud spin noise and then my E85 reboots.
