E85 & Cable Recording (NTL)
Discussion in 'Cable TV & Virgin Media TV' started by MStarkey, Jan 7, 2005.
  1. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +38
    I have a Panasonic E85 which I'm delighted with :thumbsup: especially the really easy way it records fron Sky (just put the program in the Personal Planner and set the Ext Link timer).
    However having demonstrated this to a friend who would like to get one I need to know whether this function also works with Cable (NTL).. :confused:
    Can anyone help please?
    Regards
    Martyn.
  2. andykaz
    andykaz
    Jan 4, 2005
    43
    Can't answer your question (typical), but i was considering a similar situation (E55 and Telewest), and came to the conclusion it was floored due to the box not switching itself off again at the end of the transmission (i assume that unless you start setting self defeating timers, this will ultimatly consume your entire HDD, or at least around 6 hours of it).
    Hope to be proved wrong though, although it is a bit of a non starter for me, as VR mode cannot be enabled with EXT link IIRC
  3. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +38
    This isn't a problem for me - when the program ends the E85 stops automaticaly.
    regards
    Martyn
  4. andykaz
    andykaz
    Jan 4, 2005
    43
    But does the E-85 stop because the signal being sent through the Scart lead is halted?
  5. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +38
    I'm not sure but I guess so...Some one out there must know ?
  6. jem
    jem
    Sep 24, 2002
    527
    +7
    I think you may find that most people here don't use the Ext Link set up as it only gives a composite recording. Most, IMHO, use RGB recording.
  7. MikeHarrison
    MikeHarrison
    I don't think any of the UK cable boxes output vcr control signals from timer recordings.
    If you have cable, the Tosh XS32 is probably a better choice as it can select channels on the STB (details at www.redremote.co.uk/xs32.html)
  8. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +38
    Thanks Mike - I'll check it out.
    Regards
    Martyn.
  9. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +38
    Thanks jem, I have full RGB connectivity but for some reason couldn't get it to work - I got audio but no picture - perhaps I should review this again.
    regards
    Martyn.
  10. jamils
    jamils
    I believe what you are experiencing (audio but no picture) is caused by the Copy Protection system which is present in most of these DVD recorders. I seems the cable box (I have Telewest) sends a "protect this film" signal. I also think it only happens when using the cable box and an RGB connection. Recording the same film, if it's on a terrestrial channel, doesn't pose a problem.
    I am using a full 21 pin scart cable at the moment, I might try one that doesn't have all the pins (or all the 21 cables). Is you cable "thick" or "thin". No pun intended!
    I have just posted a question about it.
    http://www.avforums.com/forums/showthread.php?t=177324
    Jamil.
  11. jem
    jem
    Sep 24, 2002
    527
    +7
    This usually means that you are not putting in an RGB signal. If you are using the VCR socket from your Sky digibox it only ouputs composite - you need to use the TV out scart.
  12. andykaz
    andykaz
    Jan 4, 2005
    43
    I have telewest and full RGB connectivity and have no problems recording from it :confused:
  13. jem
    jem
    Sep 24, 2002
    527
    +7
    Shouldn't think you would either. I think jamils may have a problem with his settings.
  14. jamils
    jamils
