E76G Anyone have one?
cammey78
I had a U8QF and loved it but had to return itdue to fault. Currently looking at the new E76G, looks very similar at a bit cheaper price at the moment. Anyone have one and can compare to the U8QF? If not as good, i'll just rebuy :) Any help appreciated.
Petey20
I think its just a variation of the new A7. If it is then it'll be an IPS panel unless you're looking at 50".
It also won't have anywhere near the HDR performance of your U8QF so probably one to avoid to be honest.
The Sony XH9505 would be comparable to your U8 and possibly even better.
cammey78
Thanks for the information Petey, I'll avoid it then :)
