KevinRoy
Established Member
Hi All,
just wondering if I have done something wrong here, I have SKY Q hooked up to my 65" E6 OLED, now i only found this by mistake.
I have SKY Q set to 2160 UHD, 10 Bit and enabled the deep colour option to allow the 10bit.
I flipped from BBC HD on SKY Q to BBC HD on freeview HD and the freeview picture was so much better than the SKY Q image it was frighting.
So I did a little digging and noticed all the SKY Q channels looked soft and washed out. the UHD stuff was good but not outstanding as Amazon or Netflix are on this set even youtube was miles better quality.
So I switched my SKY Q to 1080P and volia the picture quality improved no end like night and day from fuzzy soft tones to vibrant clean definition.
It looked miles better.
Is this an issue with SKY or my TV with some setting or other. All i did to make this massive improvement in picture quality was flip from UHD on SKY Q to 1080P HD doesnt make sense. I am currently thinking of binning SKY Q off completely and just using netflix/amazon instead as the UHD picture is shocking.
Any comments help welcome.
Kevin
Kevin
