E55 Kameleon
Discussion in 'Blu-ray & DVD Players & Recorders' started by mose72, Feb 5, 2005.
  1. mose72
    mose72
    Sep 26, 2004
    1,992
    Brighton/Glasgow
    +489
    Hi all
    Tried this in the remote forum but no response. Has anyone had any success with the Kamelon and the Panny e55 dvdr recorder? If so which codes are you using?
    BRVF
  2. joffy1780
    joffy1780
    Dec 19, 2004
    1,407
    Washington,Tyne and Wear
    +75
    Hi,I have been using the code 0 4 9 0 on my Kameleon 8,it works fine,although it does need to learn the time slip function.
  3. mose72
    mose72
    Sep 26, 2004
    1,992
    Brighton/Glasgow
    +489
    Have you got a certain button for input select?
  4. joffy1780
    joffy1780
    Dec 19, 2004
    1,407
    +75
    I have an input button at the bottom of the numeric pad,but it's that long since I set it up I can't remember whether it had to learn that or not, sorry.
    Is the code working for everything else though?
  5. mose72
    mose72
    Sep 26, 2004
    1,992
    Brighton/Glasgow
    +489
    Well, i have had a slight mishap. I got the book of words out and have managed to change the panny remote to the kameleon (there are 3 remote nos). I now get the message "remote dvd3" when using the panny one and as i dont have a function button on the kameleon i cant get into the function menu (e55) to change them back and input the leaning function on the kameleon.......that sounds garbled, hope you get my gist
  6. joffy1780
    joffy1780
    Dec 19, 2004
    1,407
    +75
    Nightmare :oops: ,that happened to me aswell as I had another panny player,
    Good Luck.
    I'm sure there is something in the panny instructions as to how to change it without the function menu,could be wrong though.
