e55 blank dvdrs
Discussion in 'Blu-ray & DVD Players & Recorders' started by novice2, Feb 10, 2005.
  1. novice2
    novice2
    Can anyone suggest decent blank dvdrs that will work with this model. I have searched the forum byt cannot seem to find the answer.
    Thanks in advance
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
  3. novice2
    novice2
    many thanks Mark
  4. cochranv
    cochranv
    I have used Bulkpaq Orange (4x and 8x) with no problems at all in my Panasonic e55. Unfortunately, if I want to edit video on my pc and copy to these, they don't work very well in dvd players. It may be due to my pc-based sony dvd writer >:/
    Anyway, I now use Datawrite Greys (Fujicode M03) and they work perfectly both on the Panasonic e55, my standalone player and on the PC.
    I have also used half a dozen Ridisc 4x disks from svp {DV 3146} which use the M02 dye. They are also spot on, on my pc and the standalone players. I bought them, expecting to get a Ritek G04 dye, but apparently, you can get one or the other with these discs.
    Good luck!
  5. slowen
    slowen
    Jan 16, 2005
    208
    16
    I use datawrite yellow (v2) or titanium about £5.50 for 25 and they use the darker ritek dye and never had any problems. I normally use all datawrite apart from classic and red as they are only about £4 for 25 but not very reliable.
    Also bought rivsion 4x (£10.50 for 50) good disk and not had any problems with them but only used about 10 upto now
  6. Baj
    Baj
    Aug 26, 2004
    64
    Canterbury
    Avoid Datawrite Yellow (V2) 4x (DVD-R). The original dye was G04 and they were vey good discs.
    I recently purchased a batch and some of them were G05 dye
    and 8x (although the packaging and discs were indistinguisable from previous purchases);
    they were completely useless;
    they appeared to be 8x rejects.
    Out of 175 discs, I threw away 100!
    Baj
  7. slowen
    slowen
    Jan 16, 2005
    208
    16
    Have used around 400 datawrite yellow 4x (v2) and never had a problem, the supplier I purchase these discs from will give you a refund on any discs that you don't use if you have a problems with compatability or if the are bad discs
  8. jpurkey
    jpurkey
    Only DVD-Rs to give me trouble in my E75 have been Memorex.
    I've used Panasonic, Sony, TDK and Verbatim without problems.
  9. CHR1S
    CHR1S
    Ritek GO4 (4x Speed only) and Datawrite 4x & 8x Fuji dyd without wasting a single disc!
