Brooktop
Established Member
Hi - not sure this should be in Freeview or DVD Recorders..so apologies if you've already seen this in the FV section, but here goes!
I have a Panasonic TUCT20 FV box going by scart to my Panasonic E55 DVDR. When I recorded progs from terrestrial analogue, it would title the recording with the name of the programme. Now I'm using digital terrestrial, it doesn't seem to be recording that info: just the time/date and the titel AV2.
Is this something to do with the RF? If so, I can't use the RF because my NTL analogue cable is using the RF (no scart output from NTL analogue).
One other question, can I use AV1 scart socket (labelled TV) on the E55 or do I have to keep it in AV2 (labelled Decoder/Ext)? If I could it would mean that I could then put back my VCR into AV2 and have all my gear connected without having to swap scart leads.
By the way, going from scart or RF direct to the TV is not an option as I have a Panasonic PW6 plasma screen with no additional terminal boards - everything is channelled from the E55 by component>VGA input on the PW6. I could potenially get a scart terminal board, but it's added cost and I'm not sure waht benefit it would be as I want to go from FV to E55 so I can record stuff.
