E50 Vs Hs2 Vs Sky+?
Discussion in 'Blu-ray & DVD Players & Recorders' started by TopMeTom, Apr 5, 2003.
  1. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    Ok ,as you can see by the title ,looking for a recorder!
    BUT,which to get??
    If I was to get the E50 andSKY+ about the same price as the hs2!
    WHAT do all you guys think?
    Value your opinion,
    Many thanks,
    Phil
    P.S.
    going out to buy 2morrow!!SAT:p
  2. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    philb - sorry can't really answer your question but I am on holiday and am going to go out to buy an E30 / E50 tomorrow! Can you suggest the best high street price on either of these?
    (I don't think I need the HS2 although I appreciate its advantages over the E30/E50)
    Thanks and good luck with your choice!
  3. Ragnar1976
    Ragnar1976
    Sep 10, 2002
    30
    Swindon
    The one big advantage with Sky+, is that it doesn't record the RED dot.:)
  4. bobbles
    bobbles
    i have the E30 and sky+ combo
    IMO it is the better option of the two but a HS2 and sky+ would be even better
    you get far more benefits with sky+ but you do have to pay the subscription fees
  5. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    what do you use the recorder for though?
    If I have the two won't the e50 be redundant,I already have a pioneer 717 player?
    Phil
  6. malcom
    malcom
    Aug 25, 2001
    526
    +4
    philb. Don't forget when comparing the cost of Sky+ and and the E50 that Sky+ is an on going cost in addition to the initial outlay (Yes that dreadfull £10 a month rip off)
    Also the Sky+ is useless for editing. If you are happy to spend that amount of dosh then without doubt go for the H2 or as I have done two DVD recorders which gives you two tuners and the advantage that gives you. Good luck. Malcom.
  7. bobbles
    bobbles
    the HS2 allows better editing before archiving than a E50
    sky+ and HS2 would allow you two record two seperate things at once
    Sky+ has many other advantages
    Two seperate Sky tuners
    Instant Rewind
    The EPG
    DD5.1 on sky movies
    etc
    Another option, which I will be doing myself is to buy one of the new RAM compatable Tosh players. These can be bought relatively cheaply with all the protection disabled which would allow you to back up any DVD if you wished to do so
    A HS2 on its own may do the job it depends what you intend to do with it. Personally, I couldn't manage without sky+ now, it is fantastic
    you may want to wait for the HS3 and a bigger Hard Drive or wait until Sky offer a better deal on sky+
  8. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Another vote for HS2 plus Sky+.
    For example I'm currently taping the West Wing S3 to the HDD of the HS2. Then I can fill up the disc with them and archive some to RAM. When I've finished with S2 I can start watching them and in the meantime their not clogging up Sky+.
  9. DaveP
    DaveP
    Can you tell me the model number of the cheapest Toshiba that can do this and the price please?
    DaveP
  10. bobbles
    bobbles
    cheapest player seems to be the S35
    S35
    AVLand seem to have it for around the 110 mark
    I prefer the look of the S75 but it is a little more
    Not sure if AVLand can mod them to disable security,
    Other sites are selling the RA82 fully modded for around the 220 mark, this is an older model which is why I am waiting for the S75.
    The S75 has component outputs
  11. DaveP
    DaveP
    Thanks Bobbles, I think I'll go for that one too, it plays back JPGs which would be very useful.
    DaveP
  12. DaveP
    DaveP
    Bobbles, you mentioned Tosh in your original text. What models do the DVD-RAM?
    Dave
  13. bobbles
    bobbles
    sorry dave i meant panny
    my first player wash a tosh
    as far as I am aware it is only the Pannys that do RAM
  14. DaveP
    DaveP
    Thanks, I've a tosh DVD-Rom drive that reads RAM disks so things may change. I'll order the Panny though, that's going to be a month or so's wait as it is so I shan't hold my breath on the Tosh's
    DaveP
    PS
    Sorry Philb for hijacking your thread!
  15. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    I'm also weighing up whether to get a HS2 or E30/50 for backing-up from Sky+.
    I'd like to be able to edit out adverts etc with pinpoiny accuaracy - does the HS2 allow you to do this?
  16. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    They all will as far as I'm aware.
  17. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    To do that on the E30/E50 though, wouldn't you have to use a RAM disc, which would be more expensive and not compatible with many DVD players?
  18. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    That's a fair point. I was thinking of my HS2 when answering. I edit using the HDD and dub to -R.
  19. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    What's the procedure for editing out commercials etc on the HS2?
  20. bobbles
    bobbles
    very simple all done on the hard disc before burning to -R
    you can edit out ads on the E30 but you will need a second RAM player, Panny have some very cheap ones coming out
  21. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    If you use a separate player and recorder though, you end up going through the digitisation process twice... or can you use a firewire connection or something?
    With the HS2, can you select particular frames at two different points and delete everything in between?
  22. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Yes its called partial erase, but I bet the E30/50 does the same when editing on -ram discs
  23. bobbles
    bobbles
    yes it does
