E50 and positioning to end of recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by pandrew, Nov 17, 2003.
  1. pandrew
    pandrew
    Dec 20, 2002
    38
    Panasonic E50 owners,
    Can someone tell me if if is possible to position to the end of a recording (DVD-RAM disk where only one program is recorded on the disk) without having to scan through the whole program to find the end of the recording.
    I would like to know if it's possible because on timer recordings I tend to overrun by 5 mins and would like to erase the bit at the end by positioning at the end and scanning backwards.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    No you need to scan through the whole programme. By pressing the FF/RW button five times you can get to maximum speed (30 times speed).
  3. pandrew
    pandrew
    Dec 20, 2002
    38
    I thought as much...
    Thanks for your reply
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Set it up to record another short program after the main timer recording, say 1 minute long. Or add a short manual recording.
    Select that and then run backwards into the previous recording.
