E4 & E4+1 EPG is Identical on HUMAX 9200T
Klopek
Anybody else find this?
Just searched through a few of my recent recordings, found them all to be not what I wanted, checked the EPG and there it was.... the channel's share exactly the same EPG! This also seems true for More4 and More 4+1.
Has anybody else got this problem? Or know how to fix it?
I haven't had the box long so I'm unsure if they were ever correct.
***This is true for the 8000T also*** - so it's probably the broadcaster's fault?
Smith2004
I believe my 9200T has this problem also. Will check later. It may be due to the broadcaster rather than the STB however.
T
tringa
The EPG for E4+1 and More4+1 seems a bit hit and miss, sometimes there is nothing there at all (on my 9200T). I suspect it is a broadcast problem rather than the player's fault, though I could be wrong.
A
alex3867
ive had problems with more4+1 and e4+1 programme listings on an old ONDigital! may likely be a broadcaster problem (and then the digifuisions must be magic....:rolleyes: )
ROYOLD
Probably because they get the 14 day epg from 4TV and not freeview.
Dune
Itis back to normal tonight on my 9200 so it must have been a broadcast problem.
Dave
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
