E4 and E4+1 on your freeview MCE setup?
Discussion in 'Microsoft Windows' started by Dunkwho, May 27, 2005.
  1. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    I've not tried scanning today (left the house too early) - anyone having any joy receiving E4 and E4+1 now that they've switched to regular freeview today? I scanned for new channels last night (and screwed my guide data, spent ages fixing a problem that wouldn't let me get to the add guide data to channel without crashing) that didn't pick up any E4, not even tutv, even though all other channels and multiplexes were around.
  2. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    Well I've just rescanned, found E4+1 but no E4, not even there as an unticked option like the other TopUp TV channels. Wonder what's up? Has anyone managed to get E4 on MCE?
  3. lisag
    lisag
    Jul 14, 2004
    5,890
    Essex
    +368
  4. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
  5. DaveP
    DaveP
  6. lisag
    lisag
    Jul 14, 2004
    5,890
    Essex
    +368
    :( I have still only got E4 :(
  7. WSB
    WSB
    Dec 31, 2004
    354
    +7
    I had the same issue. Got E4 up and running but no E4+1.
    lisag- try rescanning for Services (not channels although I think you need to scan for channels first and then scan for services). Either way- that worked for me and E4+1 came up.
  8. lisag
    lisag
    Jul 14, 2004
    5,890
    Essex
    +368
    Thanks for the tip, still no joy. I think I am in a dodgy freeview area, there are a couple of other channels I can't get. I have E4 though that's the main thing..... constant BB :rolleyes:
  9. carvakas
    carvakas
  10. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    i scanned for channels after installing UR2 so have E4, E4+1, More 4 and More4 +1 from the Sudbury Transmitter. Only thing is the EPG will show program info for E4 and More4 but lists "no information available" for the +1 incarnations. Not a problem when you just skip back an hour on the EPG for the originals but not listed all the same. :confused:
  11. cdldt
    cdldt
    Feb 1, 2006
    649
    28
    +58
    Sometimes Media Center preferences can get screwed up resulting in channels not being listed at all when scanned (the "No Information Available" problem is caused by BDS and/or Microsoft - select Crystal Palace as Guide data (use a London post-code) if you are missing lots of guide data since it's usually OK). Deleting prefs.xml and then rescanning usually cures it.
  12. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    thanks chris! ill give it a try! :thumbsup:
