B
bobbles
I currently have a Multiregion E30 and a modded S35 which is capable of playing RAM
I am seriously considering upgrading to a HS2 or even a E100
is it worth it?
How does the high speed dubbing work?
For example say I have saved 4 episodes of the west wing on sky+
I transfer them to the HS2 overnight
edit them on the HS2
High speed dub onto -R
at what speed can it do this?
Do you need the right discs, so to do at double speed do you need X2 discs?
What other advantages does the HS2 have over the E30?
What advantages does the E100 have over the HS2 other than the 80Gb drive?
Ta
is it worth it?
Ta
